How much is a turbo conversion? How long does it take? Will I really benifit from it or will I plough it through a tree in the first 2 weeks? And bear in mind I'll be 25 with 6yrs no claims.
The huge water leak from thermostat housing area on the new lump.Should I bite the bullet and just go for a nice turbo lump or should I see if the water leak is a simple fix job?
JJ wrote:The huge water leak from thermostat housing area on the new lump.Should I bite the bullet and just go for a nice turbo lump or should I see if the water leak is a simple fix job?
You've got a water leak remember, your engine hasn't been destroyed!
Just fix it and it'll be fine.
Turbo conversion!!
Well I can supply everything to your door for
£1600
+ exahaust
( customer choice
if you want to go down that route, I have a complete clip from a Rev 1 with 40k miles on it looking for a good home.
Excellent engine and gearbox, compression tested, no oil leaks or water leaks
Don't want to be a bad influence or anything!!
gtschris.com wrote:(never raced or rallied one carefull owner used to just use it to drive his mother to church and back on a sunday)
Waldo Dobbs wrote:gtschris.com wrote:(never raced or rallied one carefull owner used to just use it to drive his mother to church and back on a sunday)
Must be true, you can see the church in the background..
