Will it fit? Its all dependant on what lengths you are prepared to go to to make it fit.
The first 4 critera for me would be:
1.
Overall dimensions of the engine and gearbox unit in relation to the engine bay taking into account induction and exhaust route.
2.
On gearbox you say hewland or V.W.
So lets scratch the hewland box as thats race kit and likely to cost as much as the engine again.
So the V.W.
box will have to have drive outputs in a similar area to the original box.
some differnce is o.k.
but look at the likely drive shaft angles and predict how movement through the suspension travel will affect the driveshaft joints.
Big driveshaft joint deflections will sap power and increase the wear rate of these components.
3.
Can the gear change mechanism be adapted to suit the mr2 lever posistion and operate correctly.
Also consider clutch actuation, is it cable or hydraulic?
4.
Engine mountings.
Where are the original honda mounts fixed to the engine gearbox.
Are these in a similar place to the mount points in the car body? If not is there anything substantial in the engine bay near by to tie these mounting points together? are there any other places on the honda unit that a mount could be attached to and bear the load safely.
Maybe a complete custom engine cradle/subframe is the answer N.b.
You need some form of vibration dampening built into the custom mount or the car body will buzz like mad!
Provided these main conditions can be met mechanically then the project is a starter
There will be many other things to attend to but, for me anyway, if any of the above can't be sorted
](./images/smilies/eusa_wall.gif)
its time to look for a different engine
