Any helps
Thanks, Graham.
Bender Unit wrote:I bought a new full face bike helmet
I did something similar James..
.well the missus did.
I have got a Scrambler Helmet, the ones without a Visor.
Looks cool.
Ever played Mortal Kombat, its like a Scorpion and Sub Zero mask..
YES I AM SAD!!!
Hedgehog Dodger wrote:Bender Unit wrote:I bought a new full face bike helmet
Looks cool.
YES I AM SAD!!!
Bender Unit wrote:Graham, I have got home and had a look and my lid is made by FM and has the gold british motorsycle sport stamp which means its made to a high saftey standard.
RedMR² wrote:GET OVER HERE!!!!!
paul port wrote:You won't find many'Type-A' helmets in bike shops any more
(Type-A
= ones with the blue BSI Kyte mark label on the side)
The old BSI standard required that sample helmets from each manufacturerd batch be tested against the standard- only if they passed did the rest of the batch get the sticker.
Now..
there is a
'European' standard called ECE22-05, it only needs the design to be type approved by testing an example helmet
- after that it is up to the manufacturer to certify that subsequent batches are up to spec.
For this reason, the MSA does not accept them..
However the Motorcycle racing club
(ACU?) does, and gives them the gold sticker.
I'm hoping to get a new lid at the Historic Morotsport show near coventry this weekend!
Good point, well made.I forgot about the updates to this.
If this guys getting an open face helmet though he can go through someone like demon tweeks where you can make sure you get the right lid for the job.
Any decent motorbike helmet would be acceptable for trackdays tbh.
Paul.
Limeymk1 wrote:IIRC airbrushing/painting a helmet can effect it's structural integrity if the correct solvents are not used.So I'd avoid buying one that's already been done and make sure you use the right paints if you do it yourself.
