Just a quick question with regard to fitting a breather catch tank
There seems to be 2 breathers from the enging, 1 from below the pistons
The question is do i need to fit a Y conector into the breather lines and have 1 into the tank and use the other in/out let to vent to air, or do i just connect both breathers to each of the inlets on the tank?
Any help much appreciated
Steve.
