Any good???
Where would you hook up the 12V power supply to?? Could you tap into the existing power lighting up the lights? Or would it have to be sourced from elsewhere?
Cheers.
michael wrote:They are unlikely to be E marked for use here and as a result you could fail an MR2 with them on- the beam pattern may also be an issue.
liberty wrote:Looks like an Irish pikey has lost his hat!![]()
Kenny-Boost wrote:I'm assuming for that price its an insert into your original headlight?
so i doubt beam pattern would be an issue?
michael wrote:![]()
"why do people keep flashing me because my lights are pointing the wrong way" threads.
liberty wrote:Fail your MOT because of those lights if correctly hooked up? I don't think so.
Aslong as the light is dipped and not blinding other road users AND lights up the road infront, MOT testers would have no reason to fail you.
