Hi People
Every now and then my clutch pedal disappears into the floor, feels as if its being sucked down as i push to change gear. Still operates in this state but with about 2 inches of travel. It only comes back up if i put my foot under it and lift it up again.
It's possibly not the master cylinder mate.
I've just had the same problem, it eventually got worse until I got a rumbling noise and gear changes felt horrible.
It was suggested that it could be the cylinder leaking/faulty seals but it wasn't that.
It turned out my clutch release bearing was knackered and it's been in getting it done this week.
If it gets gradually worse, and the goes away when you press the clutch pedal that's what it'll be.
Have we tried topping it up ????????????????????????
Its in the front well, if you look at the brake reservoir, its to the right of it, below the plastic covers... you'll see the reservoir on its own. Top it up with some brake fluid and it should do the trick if the fluids run a little low !
it is most prob your master cylinder mate i av done a few. after you replace it u will prob need a vacum bleeder to bleed it off, i av come across this prob a few time and they av bin a right bas*ard to bleed if i was u i would diff try and get hold of a vacum bleeded coz it will save a lot of time and stress....
roy..
thanks guys, ive check the fluid level and its on max, where does this lead me now? if the master/slave cylinders are faullty would the fluid level be low? Not wanting to throw you guys off track.....i do however have for a while now had a rumble from my gearbox which goes when the clutch is pressed...... could this be linked to the release bearing as suggested above?
Hi Moon Monster, I had exactly the same problem a few months back and twas down to the clutch release bearing as briforbes says above, I had a "ticking" noise which was a lot more audible with the passenger door open which went away with the slightest amount of pressure applied to the clutch pedal but over a couple of weeks i had to depress the clutch further to make the noise go away and the clutch sticking to the floor became more frequent. I had the clutch replaced and had the master cylinder done at the same time. Although i was told afterwards changing the master cylinder wasn't necessary
