Rev 2 Brakes
Rev 2 Brakes
Has anybody fitted a larger master cylinder to a Rev2 tubby could do with some advice if so.
Re: Rev 2 Brakes
I think you get a larger master cyliner, with the willwood brake conversion.
if you go for 4 pot calipers front and rear.
I think its supplied to provide additional space for the fluid required to push out more pots
(16) than the OEM 6.
Re: Rev 2 Brakes
Well that is the reasoning that Rod would be looking at as he is running 4 pots.
