Hi all
New MR2 owner here, having just picked up my first MR2 on saturday.
Very impressed with the handling of it, not nearly as twitchy on the limit as i was expecting
Anyway, I was driving it hom last night after buying it and I noticed overheating.
.prior to that, it was idling erratically.
After doing a little research on various MR2 websites, I decided to flush the cooling system today and make sure there were no air pockets in the system when refilling.
This appears to have solved the problem and the car is now running sweet!
However, there was a lot of murky liquid in the expansion tank and I could not find a way to drain it.
How would I go about draining or removing the expansion tank? Does it simply pull out of it's mounting in some way?
Frank
MR2 Mk1b
