The harness was all over the shop, proper bodge job, mast never worked as it should it was turn key mast up turn key off mast down zero other control.
Anyway I get normal headunit opperation bar sound,.
1,4,7 or 12?
Ashy wrote:The signal from the head unit to acitvatethe AMP is Pin 1
FYI See: http://www.ashworthonline.org.uk/mr2/MR ... Aerial.pdf
