The new alternator works fine, but I'm having trouble getting the tension in the belt set right.
At the moment, it seems the only way to do it is slacken the adjuster off, then try and get some pressure on the adjuster bolt moving it to the back of the car whilst simulataneously doing the bolt up with a ratchet.
I'm thinking there must be a better way to do this
Ben.
