stupid little springs on brake pads....argghh!!
misterT
Post by misterT »
Can anybody give me a clue how those horrible, little, fiddly, annoying springs go back into the front brake pads??? :evil: Either i'm missing something, thick as something smelly n brown or my fingers are an abnormal shape that prevents me from ever doing such a 'simple' pad change on my 2 ever again! Help.... please!
Peter Gidden
Re: stupid little springs on brake pads....argghh!!
Post by Peter Gidden »
I'm changing a set for a customer tomorrow, so i'll post a couple of pics up after the job.
Poohbear
Post by Poohbear »
The little bent legs of the springs fit into small holes drilled in the curved metal outer edge of each pad. There are two springs for each set of pads. You put the top spring in with the tip of the 'v' shape pointing down and the bottom spring with the tip of the 'v' pointing up. So they oppose each other like this.... > <
edit:Sorry Peter..was putting together this post while you were submitting yours lol.
HTH...Bob
I'm Going To Die Young...But When I'm Very Very Old!
JohnnyC
Post by JohnnyC »
Does you mean the Y shaped anti-squeal spring?
If so, have a butchers here, there's a small hole in the pad for it to fit...
Edit: Hope the pic works, imageshack seems to be running on a 56K modem again!!! Hence my delayed post too, hadn't realised others had posted.
phild
Post by phild »
try this trick out
put together the pads and the springs outside of the calliper and bind the bundle together with some insulation tape, drop it into the calliper and when in position, cut the tape and the springs will spread out and push the pads into position without too much fuss, saves having to grow another hand. :D
misterT
Post by misterT »
:D Thanks very much everyone. Now sorted. Thanks for picture JohnnyC, exactly what i needed. Seems stupidly obvious now... #-o
scann2
Post by scann2 »
Had to do this job also last year, made me scream with anger after a while :twisted: Took me ages to sort it, what a pain!!!!
cantfindausername
Post by cantfindausername »
Only time those springs annoyed me was when I looked at my shiney new brakes and saw them laying on the floor. #-o :lol:
***RIP Car13 ***
*** Now in an Evo ***
