Silicone hose kits (Turbo - inlet piping)
Forum For IMOC Group Buys
Bender Unit
Post by Bender Unit »
Here is an example of the various hose colours.
http://www.iq-parts-shop.nl/images/DV1.jpg
Can everyone interested in a set please check their details listed below, and correct the relevant information?
When I know exactly who wants what I can finalise everything and get the order underway – payment will be needed in full before the order will be placed so can everyone please send the money immediately when the order is confirmed.
Known details
keith.mcclorry – Rev2 – Blue (Stock IC)
stevel - Rev3 - Blue (Stock IC)
JohnA – Rev1 – Red – (Stock IC)
misterT – Rev2 – Red – (Stock IC)
Nige_B – Rev2 – Red – (Stock IC)
Jode – Rev3 – Yellow - (Stock IC)
Muffleman – Rev1 – Green - (Stock IC)
Outstanding details ……
bidtowin – Rev? – Colour? - (Stock IC?)
mr2turbo117 – Rev? – Colour? - (Stock IC?)
Stu Wilson – Rev2 – Red - (Stock IC?)
Different IC’s – need to supply measurments
DannyW – Rev? - Blue (Different IC)
Need pipe ID/OD and Length for different sections –– (ARC IC)
Gaz6002 – Stock / CC? – Colour? (Different IC)
Need pipe ID/OD and Length for different sections –– (ST205 CC)
CosmosblueMR2 – Rev3 – Purple (Different IC)
jimGTS – Rev2 – Red – (Different IC)
Need pipe ID/OD and Length for different sections –-(Greddy IC)
rwilson_ie – Rev3 – Colour? – (Different IC)
Need pipe ID/OD and Length for different sections –– (ST205 CC) ?? Still in?
Coolant hoses, airbox to turbo etc are possibles, I will start a seperate thread about the possibiltiy of kits, please post you interest for Coolant kits in the other threads.
ust wondered if anyone is interested in a silicone hose kit for the MR2 turbo?
Pretty much all the main colours are available
Red
Blue
Green
Black
Yellow
Purple
The kit in question is for the stock Mr2 intercooler and is identical to OEM not like the Samco pipes which are designed around using a different dump valve. Prices should be around £70 to you door which is much cheaper.
If you have an aftermarket intercooler kit I can also supply the replacement pipework for that as well (if you want matching pipes). Prices for the aftermarket kits will have to be worked out but I suspect them to be cheaper than the stock kit as less hose is needed. Please get in touch so I can work out the order.
Numbers needed in the GB are ideally 20 or more - if I can gauge the interest then I can speak to the manufacturer to see if its worth them doing the job.
Quality is top notch from a reputed manufacturer.
Pictures to follow as soon as I can find them on my HD! Needless to say they bling the engine bay up and look good.
James
DannyW
Re: Silicone hose kits (Turbo - inlet piping)
Post by DannyW »
I'm in. any idea where to get good quality mikalor style clamps from too? (maybe incluce them in the kit?)
I have an ARC intercooler which uses 3 small pieces of hose instead of the 1 long piece as on the stock item. but the rest is the same as stock.
cheers!
DannyW
-:[KM]:-
Post by -:[KM]:- »
I'll have a set, no problem.
To suit a rev2 of course!
philz
Post by philz »
I bought a set from James a while back, see below
BTW James, got my Lucky 7 yesterday :)
Bender Unit
Hi Steve,
Thanks for the pictures mate, I was hoping you would come through on that one :D
Cool hows the Lucky 7? I couldnt get them cheap enough on the GB for everyone to be interested so I gave it a miss as I was a bit low on funds at that point. Still I have a Quadard coming which was a freebie with my mobile phone deal (basically mini quad - and you can drift them!)
I may get a Lucky 7 at some point but I struggled riding the mini moto so I went for a quad instead. If your interested Cheddar do a track night for the Moto's every Mon, Wed, Fri for £15 for as long as you want - Would be cool to hook up and go for a blat :D
James
Bender Unit
Danny,
I can sort the Mikalor clams as well if you want - prices to follow (need to hunt around for the best price as these vary greatly)
I can also do a kit for the ARC intercooler, you will need to do me a small favour though and measure the piping lengths and internal diameters of the additional hose sections that ARC supply with the kit.
TBH you kit should be alot cheaper than the OEM kit as you effectivley wont need the formed long hose which bumps costs up.
What colour do you want?
James
Bender Unit
Keith,
What colour are you after? Do you still have the stock IC?
James
Gaz6002
Post by Gaz6002 »
I am interested mate, do you have any more pics? I got the standard i/c at the mo cos im saving for a CC conversion but would love a kit in red if the qualitys ok
Modded Supra TT6
DannyW
Post by DannyW »
Bender Unit wrote:Danny,
Ok mate nice one, i'd be after blue hoses.
I can measure them all up at the weekend.
Mikalors would be cool too for piece of mind.
cheers!
DannyW
Muffleman
Post by Muffleman »
Yup interested here, in Green :shock:
Can you do the coolant hoses too ?
Matt
Pete
Post by Pete »
I'd be interested in coolant hoses.
Bender Unit
Scroll up to Philz's post and you will see the kit in red, sorry its not a close up but Philz's car is on the stock IC. The hose quality is top notch and the company in question supply alot of race and rally teams.
James
Bender Unit
cheers!
DannyW
Noted, will pop you on the list and see what I can do on the Mikalor front. Be warnded they are stupidly strong clamps, i found this out when I actually distroted one of my boost hoses with one! :D
James
Bender Unit
Matt
Cool, makes a change from the red, and blue orders :D Its a pretty lurid light green though, would definatley look different. :D
James
Bender Unit
Coolant hoses are a possibility, and the company I will be using are very keen to fabricate a set.
Obviously I need some spare hoses which can be used for tooling purposes before they can make the finished article. I tried tracking some down but didnt get far as I was pre occupied with my engine build at the time.
If anyone can help me out with these spare hoses then that would be great. i will ask around.
James
Pete
Post by Pete »
I may be able to provide the original hoses you need to work from. It just depends when i get chance to get at my car as it's waiting the engine coming out for a rebuild this winter, and i'm v busy at the minute.
I'll let you know if i get anywhere with it.
Muffleman
Post by Muffleman »
Bender Unit wrote:Cool, makes a change from the red, and blue orders :D Its a pretty lurid light green though, would definatley look different. :D
Lurid eh ? Hmmm. A good match for this then :mrgreen:
Just let me know, but definitely interested in turbo and coolant hoses 8)
-:[KM]:-
Post by -:[KM]:- »
James!!
Need a set of blue hoses... Any idea when they will be available?
And ... clamps too!! =P~
**edit**
Yep, stock intercooler, dude.
Bender Unit
lol nice colour! :D The hose colour is almost identical to that s they will be a perfect match!
Bender Unit
James!!
**edit**
Need to get a bit more interest really mate, so far its only a few people wanting them the bigger the order the greater preference we have with the maker.
Clamps wont be an issue, as those will just be off the shelf.
James
Return to “Group Buys - MR2 related”
