Front:
Stock 6" Wheel Offsett is 35.05 mm tucked in from flush
(flush offset: 9.95).
7" Wheel Offsets(flush offset: 22.65):
19
- Front wheel offset will be 3.65 mm further out than flush.
20
- Front wheel offset will be 2.65 mm further out than flush.
21
- Front wheel offset will be 1.65 mm further out than flush.
22
- Front wheel offset will be 0.65 mm further out than flush.
23
- Front wheel offset will be 0.35 mm tucked in from flush.
24
- Front wheel offset will be 1.35 mm tucked in from flush.
25
- Front wheel offset will be 2.35 mm tucked in from flush.
26
- Front wheel offset will be 3.35 mm tucked in from flush.
27
- Front wheel offset will be 4.35 mm tucked in from flush.
28
- Front wheel offset will be 5.35 mm tucked in from flush.
29
- Front wheel offset will be 6.35 mm tucked in from flush.
30
- Front wheel offset will be 7.35 mm tucked in from flush.
31
- Front wheel offset will be 8.35 mm tucked in from flush.
32
- Front wheel offset will be 9.35 mm tucked in from flush.
33
- Front wheel offset will be 10.35 mm tucked in from flush.
34
- Front wheel offset will be 11.35 mm tucked in from flush.
7.5" Wheel Offsets(flush offset: 29):
25
- Front wheel offset will be 4 mm further out than flush.
26
- Front wheel offset will be 3 mm further out than flush.
27
- Front wheel offset will be 2 mm further out than flush.
28
- Front wheel offset will be 1 mm further out than flush.
29
- Front wheel offset will be flush.
30
- Front wheel offset will be 1 mm tucked in from flush.
31
- Front wheel offset will be 2 mm tucked in from flush.
32
- Front wheel offset will be 3 mm tucked in from flush.
33
- Front wheel offset will be 4 mm tucked in from flush.
34
- Front wheel offset will be 5 mm tucked in from flush.
35
- Front wheel offset will be 6 mm tucked in from flush.
36
- Front wheel offset will be 7 mm tucked in from flush.
37
- Front wheel offset will be 8 mm tucked in from flush.
38
- Front wheel offset will be 9 mm tucked in from flush.
39
- Front wheel offset will be 10 mm tucked in from flush.
40
- Front wheel offset will be 11 mm tucked in from flush.
8" Wheel Offsets(flush offset: 35.35):
31
- Front wheel offset will be 4.35 mm further out than flush.
32
- Front wheel offset will be 3.35 mm further out than flush.
33
- Front wheel offset will be 2.35 mm further out than flush.
34
- Front wheel offset will be 1.35 mm further out than flush.
35
- Front wheel offset will be 0.35 mm further out than flush.
36
- Front wheel offset will be 0.65 mm tucked in from flush.
37
- Front wheel offset will be 1.65 mm tucked in from flush.
38
- Front wheel offset will be 2.65 mm tucked in from flush.
39
- Front wheel offset will be 3.65 mm tucked in from flush.
40
- Front wheel offset will be 4.65 mm tucked in from flush.
41
- Front wheel offset will be 5.65 mm tucked in from flush.
42
- Front wheel offset will be 6.65 mm tucked in from flush.
43
- Front wheel offset will be 7.65 mm tucked in from flush.
44
- Front wheel offset will be 8.65 mm tucked in from flush.
45
- Front wheel offset will be 9.65 mm tucked in from flush.
46
- Front wheel offset will be 10.65 mm tucked in from flush.
8.5" Wheel Offsets(flush offset: 41.7):
38
- Front wheel offset will be 3.7 mm further out than flush.
39
- Front wheel offset will be 2.7 mm further out than flush.
40
- Front wheel offset will be 1.7 mm further out than flush.
41
- Front wheel offset will be 0.7 mm further out than flush.
42
- Front wheel offset will be 0.3 mm tucked in from flush.
43
- Front wheel offset will be 1.3 mm tucked in from flush.
44
- Front wheel offset will be 2.3 mm tucked in from flush.
45
- Front wheel offset will be 3.3 mm tucked in from flush.
46
- Front wheel offset will be 4.3 mm tucked in from flush.
47
- Front wheel offset will be 5.3 mm tucked in from flush.
48
- Front wheel offset will be 6.3 mm tucked in from flush.
49
- Front wheel offset will be 7.3 mm tucked in from flush.
50
- Front wheel offset will be 8.3 mm tucked in from flush.
51
- Front wheel offset will be 9.3 mm tucked in from flush.
52
- Front wheel offset will be 10.3 mm tucked in from flush.
53
- Front wheel offset will be 11.3 mm tucked in from flush.
Rear:
Stock 7" Wheel Offset is 35.05 mm tucked in from flush
8" Wheel Offsets(flush offset: 22.65):
19
- Rear wheel offset will be 3.65 mm further out than flush.
20
- Rear wheel offset will be 2.65 mm further out than flush.
21
- Rear wheel offset will be 1.65 mm further out than flush.
22
- Rear wheel offset will be 0.65 mm further out than flush.
23
- Rear wheel offset will be 1.35 mm tucked in from flush.
24
- Rear wheel offset will be 2.35 mm tucked in from flush.
25
- Rear wheel offset will be 3.35 mm tucked in from flush.
26
- Rear wheel offset will be 4.35 mm tucked in from flush.
27
- Rear wheel offset will be 5.35 mm tucked in from flush.
28
- Rear wheel offset will be 6.35 mm tucked in from flush.
29
- Rear wheel offset will be 7.35 mm tucked in from flush.
30
- Rear wheel offset will be 8.35 mm tucked in from flush.
31
- Rear wheel offset will be 9.35 mm tucked in from flush.
32
- Rear wheel offset will be 10.35 mm tucked in from flush.
33
- Rear wheel offset will be 11.35 mm tucked in from flush.
34
- Rear wheel offset will be 12.35 mm tucked in from flush.
8.5" Wheel Offsets(flush offset: 29):
25
- Rear wheel offset will be 4 mm further out than flush.
26
- Rear wheel offset will be 3 mm further out than flush.
27
- Rear wheel offset will be 2 mm further out than flush.
28
- Rear wheel offset will be 1 mm further out than flush.
29
- Rear wheel offset will be flush.
30
- Rear wheel offset will be 1 mm tucked in from flush.
31
- Rear wheel offset will be 2 mm tucked in from flush.
32
- Rear wheel offset will be 3 mm tucked in from flush.
33
- Rear wheel offset will be 4 mm tucked in from flush.
34
- Rear wheel offset will be 5 mm tucked in from flush.
35
- Rear wheel offset will be 6 mm tucked in from flush.
36
- Rear wheel offset will be 7 mm tucked in from flush.
37
- Rear wheel offset will be 8 mm tucked in from flush.
38
- Rear wheel offset will be 9 mm tucked in from flush.
39
- Rear wheel offset will be 10 mm tucked in from flush.
40
- Rear wheel offset will be 11 mm tucked in from flush.
9" Wheel Offsets(flush offset: 35.35):
31
- Rear wheel offset will be 4.35 mm further out than flush.
32
- Rear wheel offset will be 3.35 mm further out than flush.
33
- Rear wheel offset will be 2.35 mm further out than flush.
34
- Rear wheel offset will be 1.35 mm further out than flush.
35
- Rear wheel offset will be 0.35 mm further out than flush.
36
- Rear wheel offset will be 0.65 mm tucked in from flush
37
- Rear wheel offset will be 1.65 mm tucked in from flush
38
- Rear wheel offset will be 2.65 mm tucked in from flush
39
- Rear wheel offset will be 3.65 mm tucked in from flush
40
- Rear wheel offset will be 4.65 mm tucked in from flush
41
- Rear wheel offset will be 5.65 mm tucked in from flush
42
- Rear wheel offset will be 6.65 mm tucked in from flush
43
- Rear wheel offset will be 7.65 mm tucked in from flush
44
- Rear wheel offset will be 8.65 mm tucked in from flush
45
- Rear wheel offset will be 9.65 mm tucked in from flush
46
- Rear wheel offset will be 10.65 mm tucked in from flush
9.5" Wheel Offsets(flush offset: 41.7):
37
- Rear wheel offset will be 4.7 mm further out than flush.
38
- Rear wheel offset will be 3.7 mm further out than flush.
39
- Rear wheel offset will be 2.7 mm further out than flush.
40
- Rear wheel offset will be 1.7 mm further out than flush.
41
- Rear wheel offset will be 0.7 mm further out than flush.
42
- Rear wheel offset will be 0.3 mm tucked in from flush.
43
- Rear wheel offset will be 1.3 mm tucked in from flush.
44
- Rear wheel offset will be 2.3 mm tucked in from flush.
45
- Rear wheel offset will be 3.3 mm tucked in from flush.
46
- Rear wheel offset will be 4.3 mm tucked in from flush.
47
- Rear wheel offset will be 5.3 mm tucked in from flush.
48
- Rear wheel offset will be 6.3 mm tucked in from flush.
49
- Rear wheel offset will be 7.3 mm tucked in from flush.
50
- Rear wheel offset will be 8.3 mm tucked in from flush.
51
- Rear wheel offset will be 9.3 mm tucked in from flush.
52
- Rear wheel offset will be 10.3 mm tucked in from flush.
10" Wheel Offset(flush offset: 48.05):
44
- Rear wheel offset will be 4.05 mm further out than flush.
45
- Rear wheel offset will be 3.05 mm further out than flush.
46
- Rear wheel offset will be 2.05 mm further out than flush.
47
- Rear wheel offset will be 1.05 mm further out than flush.
48
- Rear wheel offset will be 0.05 mm further out than flush.
49
- Rear wheel offset will be 0.95 mm tucked in from flush.
50
- Rear wheel offset will be 1.95 mm tucked in from flush.
51
- Rear wheel offset will be 2.95 mm tucked in from flush.
52
- Rear wheel offset will be 3.95 mm tucked in from flush.
53
- Rear wheel offset will be 4.95 mm tucked in from flush.
54
- Rear wheel offset will be 5.95 mm tucked in from flush.
55
- Rear wheel offset will be 6.95 mm tucked in from flush.
56
- Rear wheel offset will be 7.95 mm tucked in from flush.
57
- Rear wheel offset will be 8.95 mm tucked in from flush.
58
- Rear wheel offset will be 9.95 mm tucked in from flush.
59
- Rear wheel offset will be 10.95 mm tucked in from flush.
