However the new boots wont fit in at all.
i got the calipers out and the below are the measurements.
17.2mm OD new boot
15.5 IDA caliper slider
any ideas where i may have gone wrong?
](./images/smilies/eusa_wall.gif)
i used this guide:
forums/kb.php?mode=article&k=190
C35Rob wrote:You haven't got the remains of the old slider boot metal base still in the carrier, have you?(It certainly looks like it)
C35Rob wrote:Image Replaced With URL For Quote
http://urlur.com/a/z3Vaovu
It does look like the old metal base is still in there(I've made the same mistake myself) give that a few taps with a screwdriver/chisel and a hammer and see if it pops out
raptor95GTS wrote:holy moses that is well pitted!
Gazza_DJ wrote:Wow.Never seen one that bad!
Be sure to check the bore inside the caliper.They may be unserviceable looking at that!
Gazza_DJ wrote:Have you got the little bushing that goes on the end of the slider as well?
47769-50010
http://japan-parts.eu/toyota/jp/1994/mr ... over#47769
