To get all of the wiring/plugs/sensors/ECU/distribution servo's
& all the mechanical bits you would ideally need a complete JDM car of the same revision as yours to take the parts from.
It will require the dashboard
& frunk stripping completely, all under trays removed
& possibly more
(fuel tank? Can't recall from memory) to run the AC lines, front bumper removed which if you've never done it will be a trial in rusted forever-spinning bolts.
Mammoth task.
If you can't be bothered with all that,
& just want
'aircon'
- it's probably easier to just grab the OEM compressor, condenser
& some or all of the AC lines
& the evaporator box
(assuming it mates to the UK blower fan
& the rest of the system ok), install that, have the missing AC lines made up with custom AC hose,
& rig it up to come on with a simple button, like how the aftermarket systems work.
The only controls/sensors needed would be the AC pressure
& evaporator temperature I think.
