Have a look around the slave cylinder and the Flexi line to it.
You don't need to leak much to cause this problem.
If there are no leaks try a 2 man bleed.
With the back end up on axle stands you can get to the bleed nipple from underneath.
After bleeding a couple of squirts try pushing the rod into the slave whilst opening the nipple to back bleed.
Then carry on the the 2 man bleed as normal.
If doing that doesn't sort it and no leaks are present then it is likely the master cylinder seals are knackered, letting fluid past the plunger rather than pushing it.
