How do i get access to the cable/other side of the nut, its as if its somewhere above the wheel arch.
hopefully im being stupid
pbmr2 wrote:the cable runs from the lever, across the rear cabin wall to under the left window and then goes back there.![]()
Can remove the trim below the window(where the speaker is) and gain access that way.
Have to take the lower lid trims off too to get it out.
