I have a boost controller and the gauge is showing boost of 1.2bar, when the car has power and doesn't.
It is a rev3.
No nginr codes other than 42 and 47 which I expect as I don't have ABS on the car and the car was running fine before with these codes.
I did have the ECU repaired recently, could this still be faulty.
If it's a boost leak would it still be able to get to 1.2bar.
