As you can see.
I've removed the 2 screws each side underneath the side engine covers.
Ross.
alanmr2turbo wrote:The rear surround is fixed from the inside of vehicle by 6 or 8 bolts, cant remember how many exactly
Gazza_DJ wrote:Been there.![]()
You need to remove the plastic trim at the bottom that surrounds the window.Top and bottom piece IIRC.
The fasteners should then be obvious.
Gazza_DJ wrote:Yes, inside, basically all the plastic trim that's behind the seats and around the rear window.
abovetherim wrote:There may be discs of rubbery stuff covering the hole the nut is behind in the top 2 corners.
