ive
just got my car back from the garage after having a new built engine and while it was out the gearbox was rebuilt
the mechanic said the passenger side driveshaft is weeping oil
.when I got it home I jacked it up to have a look and there was no leak and it was dry
I pulled the shaft out and it started leaking then pushed it back in and the leak stopped.
is it leaking cause the cars jacked up or is something else wrong
there's a bit of a gap between the metal dust guard and the seal but I couldn't push the shaft in any further
.cheers
