Advice on handling setup wanted.
Recently bought a full Superpro bush kit and Front
Whiteline ARB's
For anyone that has fitted Whiteline ARB's, which did you find the
optimal adjustment for Majority fast road with occasional track use
I'm aware this is of course down to preference as the different holes will
allow different characteristics.
Neutral setup that balanced between neutralising understeer but didn't make me fight oversteer
I'm running Meister R zeta R coilovers, Toms Front and rear braces, and will have
a Hunter 4 Wheel alignment setup done following fitment so if anyone has good specs for Toe/Camber etc that would also help.
thanks in advance.
