[quote="shinny"]
[quote="mr2_maverick"]
[quote="shinny"]From memory.
Under the cabin: Fuel tank, radiator hoses, handbrake cables
Behind the front bumper: Radiator, radiator fan(s), possible aircon condensor
Inside the frunk: Steering column, power steering pump and driver, clutch master cylinder, possibly ABS actuator, wiper motor[/quote]
Just checked and it's the bits towards the rear of the cabin that's broken.
The plastic undertray under the frunk is fine.
How weak are the radiator hoses?
[/quote]
If you're getting that area full of snow etc, your handbrake mechanism freezing is the main issue.
The radiator pipes are metal so will survive a short period of time without the undertrays but, given the amount of salt around right now, I'dm advise getting the pipes etc.
cleaned up when you sort out the undertray.
[/quote]
I have cleared the snow from the handbrake cables, I'm guessing these are the rubber covered cables nearer to the driver's side? The snow is still pressed against the left hand side where I think the radiator hose is.
It's so compressed and hardened that I can't take it out without pushing a screwdriver in or something sharp so I'll just leave it to melt out then wash the underside.
do you think the force at motorway speeds is enough to break the pipes? The maintains temperature fine but I'll check the coolant tomorrow once it's properly cold.
Handbrake cables seem ok but it's dark right now.
