Bear in mind that the front wheel clearance with coilovers varies a little depending on the coilover and how you've got them set up.
With most coilovers there is some
'play' between the hub carrier and the coilover
(same as OE) so there's some camber adjustment available there as well as at the top mount.
At 8J ET35 you may find you need to add positive camber at the hub
(this moves the top of the wheel away from the coilover) and then compensate by adding more negative camber at the top mount.
Or, add a few mm spacer.
