Just want to check my pipes etc are in the right place as I've replaced everything.
So first up, the two ports on the back of the intake manifold.
Top side, larger loop around the TB to MAP sensor, small loop as I'm removing the charcoal canister.
I've put the line in here from the hot pipe to the L shaped hard line next to the distributor, but looking at the diagrams this is for the charcoal canister, right? So I can just cap this off instead?
Turbo to wastegate actuator:
These two for the turbo vsv
And the wastegate actuator connection mentioned above:
Manifold to fuel pressure regulator:
And finally, the small port on the catch can goes back to the head at the corner, right?
