Now as I have listed in my recent update on the car,
http://www.imoc.co.uk/forums/viewtopic. ... &start=280
after returning from its initial mapping session at Fensport, it was having
issues that I believed to be boost cut.
to 18v and my Link G4 Storm ecu having a 18v map cut was causing
the sudden cut outs on power.
Now my issue is that they mapped the car at the 16v that they then found it
running at after the mapping gear was re-installed.
run lower than this they should have noticed this in the first place
My problem is, that I had to take a day off work, drive the 2
and back, costing a tank of Shell V Power, and pay for an hours labour to
diagnose
mentioned that it will need to go back up there for 2 hours mapping, after
the alternator is re-conned to tweak the map back down to the correct voltage.
Here inlays my question.
my engine builder, doesn't seem to think so
off work and all the above, but with the added cost of two hours labour.
Im in the frame of mind to be asking for the 2 hours of mapping to be free of
charge as they surely should have seen that it was running high voltage on the
I know this is more of a question of practice but I'm honestly stuck on how
to proceed, money is tight this month and I'm currently driving the MR2 out of
boost in this amazing weather as advised by Adrian.
to reiterate, does it need mapping again
thanks,
Jordan.
