Heater Hose Required!!
smithy3793
Post by smithy3793 »
After finding a leak on my 1987 MR2
I had got underneath to find that this was coming from the rubber hose which connects to the metal pipes for the heater.
Unfortunately I cannot find the part anywhere, after calling Toyota they have informed me that this is no longer available from themselves. The part number is 87245-17091 I believe.
Can anybody assist? I am located Birmingham UK.
Thanks in advance
Matt :thumleft: :thumleft:
mark35
Water hose
Post by mark35 »
Think there are some on eBay Stoney racing sell them as a upgrade. Item number 172237047516
jon_st205
Re: Heater Hose Required!!
Post by jon_st205 »
Beware it may be the metal pipe itself. If you go for silicone pipe, use a bit of instant gasket and a good quality clamp as they don't seal as well.
jimi
Post by jimi »
jimi
Post by jimi »
I had something similar happen, but it wasn't the actual hoses that were causing the problem. Have a read of this thread http://www.imoc.co.uk/forums/viewtopic. ... ight=close
it may help.
smithy3793
Do you remember what size the clip was as i will replace with a jubilee clip
thanks
Matt
jimi
Post by jimi »
Sorry, I don't, it was 7 years ago. However by zooming into the pictures I can see the sizes on some of the clips. one is 11--15mm and another is 11--25mm. IIRC I just used what I had, the hoses are the same size either end.
