It really is in very good condition there is just starting to show a small amount of rust on the nearside arch but it is still very solid
Engine
Normally aspirated 3.0Litre V6 engine from Toyota Camry
Intake cone filter attached to AFM in place of original air filter
Aluminium Fidenza flywheel
Standard exhaust system from Yoyota MR2 MK2 GTS with connecting pipe modified to match Camry downpipes
Engine mounts custom fabricated from 4mm mild steel with chassis members reinforced to suit
Engine rubber insulators from Toyota MR2 MK2 GTS
Transmission
Standard Toyota Celica GT4 clutch
Gearbox Toyota MR2 MK2 Rev3 Turbo with LSD
Driveshafts combination of Camry
Suspension
KYB gas shocks absorbers front
Rear anti-roll bar upgraded to MR2 MK2 Turbo 19mm unit
Brakes
Standard front discs upgraded from 256mm to 280mm diameter
Standard front calipers upgraded to Willwood 4 pot calipers
Wheels
TSW Apex 16" Alloy wheels
Yokohama A539 205/45 R16 87V
It's MOT'd until December 2017
So if you have got this far you may well be interested, so finally the price, it's
