i got a replacement non Toyota one from local spares place, the plugs match and so do the two mounting points except for the fact that on the standard Toyota one the measurement between the two mounting holes is 16.5 cm and yet the one i got back, despite having the correct plugs mounting points in the correct place only measures 16cm which means there isn't enough clearance to get both bolts in.
