For the MR2 Turbo model as it was never sold in the U.K. and is not on the MOT car database am I right in believing an MOT centre can't put it through as a cat test up until 1st August 1995? after that regardless from my understanding everything needed a cat.
I've done some research and get mixed info so would appreciate firsthand experience.
MR2 Turbo and De-Cat Question
Re: MR2 Turbo and De-Cat Question
You are correct.
markstevieandmads wrote:You are correct.
Thanks mate.
Please post the MOT legislation that states this please
Odin_S wrote:Please post the MOT legislation that states this please
Based on my info this is what I based it on.
https://www.gov.uk/government/uploads/s ... dition.pdf
I don't claim to be an expert on this hence my question of experiences others have had.
I have this already, it doesn't say categorically that an import car doesn't need a cat.
this has been covered many times before...
as a grey import vehicle the mr2 with a 3sgte engine is not in the MOT computer and is therefore subject to a NON-CAT test, (for cars manufactured 1/8/1992 to 31/7/1995) assuming that you've removed the cat in a way that doesn't make it patently obvious there used to be one there
for vehicles manufactured after 31/7/1995 they must have a cat and will be subject to a BET test, again as there is no match in the emissions 'book'
we all know the car came with a cat from the factory, and the book says if it had one and it's been removed then it's a fail
regardless of date of manufacture BUT the mot tester has no way of proving this (as long as you've not bashed the innards out of the stock cat etc) as it's not a type approved vehicle so has to give the benefit of the doubt if you show up with no cat on a pre 31/7/1995 car
there are exceptions, Q plates, kit cars etc.. but it's really quite straightforward, if you own a pre 31/7/95 car then fit a decat and take it to a tester who interprets the rules properly - and don't rock up saying "hi, I've de-catted my car, will you pass it please?"
Reason for failure: A catalytic converter or particulate filter missing
where one was fitted as standard.
Thanks Nic. Explains why on my mx5s they also sometimes go through the non-cat test as the chassis number doesn't match the listings.
My point exactly, means it's still at the discretion of the tester. If the tester knows he's cars he could be a nob.
Odin_S wrote:regardless of date of manufacture BUT the mot tester has no way of proving this (as long as you've not bashed the innards out of the stock cat etc) as it's not a type approved vehicle so has to give the benefit of the doubt if you show up with no cat on a pre 31/7/1995
Pre August 1995 cars, what is he going to test emissions to?
My 94 Rev 3 turbo was cleaner with the cat removed
craig wrote:Odin_S wrote:regardless of date of manufacture BUT the mot tester has no way of proving this (as long as you've not bashed the innards out of the stock cat etc) as it's not a type approved vehicle so has to give the benefit of the doubt if you show up with no cat on a pre 31/7/1995
ST205 Celica?
Section 7.3:
For those converting a late NA to turbo with an older engine:
This is important, as following the processes and flowcharts in Section 7.3C lead us here:
There is no exact match in the emissions book as there was never a UK market 3SGTE powered MR2. Therefore you have to answer no, which leads you to the non-CAT test for cars / engines before 31st July 1995.
The full text in Section 7.1 for checking of the presence of a manufacturer fitted catalytic converter is as follows:
As 7.3C tells us a non-CAT test is required, no cat is required.
A personal import must be tested according to its date of first use. The only exemption to this is if the vehicle owner can present to the tester at time of test a letter from the vehicle manufacturer stating that the particular engine as originally installed could not meet the equivalent British emission standards.
Vehicles fitted with a different engine must be tested to the requirements of whichever is older, the engine or the vehicle.
e.g. A 1995 car fitted with a 1991 engine (of whatever make), test to 1991 standards for emission purposes.
On spark ignition engine vehicles that qualify for a full catalyst emissions test and all compression ignition vehicles check the presence of catalytic converter(s) and particulate filter(s).
Note: To ascertain whether a spark ignition engine vehicle qualifies for a full catalyst test, use the flow charts in Section 7.3.C disregarding the result of the Basic Emissions Test.
Odin_S wrote:
ST205 Celica?
Not an MR2, not an exact match.
Gazza_DJ wrote:Odin_S wrote:
ST205 Celica?
Odin, as Gazza's reply.
