anyway what do you think? if I did them again I'd do them out of lighter stainless.
https://www.facebook.com/kennymr2build/ ... =3&theater
C35Rob wrote:
I've got a set of cusco adjustable tension rods on mine
I just tried searching for cusco tension rods and the only rev3+ type ones I could find were used on yahoo japan, then when searching the part number stamped on them it came up with an earlier type(the straight end part)?
tiff_lee wrote:
Nengun list them for pre and post 91 models although oddly they both have the same part number, the same part number that is stamped on those later revision used ones which when google'd only brings up images of the early model><.
