I'm actually studying a 300 bhp engine setup
I actually run without cats
May i face a power limiting factor
Do you know if there's any other flow bottleneck in the stock exhaust system?
Regards
Not sure on the diameter but would think 2.5 or 2.75 all the way through would be fine.Larger is just a waste and noisier at those power levels.
Al-sw20 wrote:The inlet to the stock muffler is a restriction as well.If you are prepared to open up the stock muffler and replace the factory inlet with a 3" pipe, it really frees it up.
