As far as I know it supposed to have LSD in it
The gear selector cables on MR2 goes from the other side.
I don't know anything about E56, but if it fits rev3 MR2 engine it must fit in engine bay as well.
I got only S54 axles.
Will E53 axles fit E56 box
What clutch will I need
I assume E56 clutch and probably Turbo pressure plate
Is there any way to connect thiner NA shaft ends to thicker Celica shafts coming out of the gearbox
Has anyone done it so far
I never heard of anyone by far at least.
If I want to meke the E56 selector shaft come out from the other way like in MR2 will I have to open the gearbox or can I just replace the selector shaft assembly
I remember that I snapped the shaft somehow in past and could select just 1st and 2nd gear.
