I've only had it pretty much sat on the cam cover to check for clearance under my strut brace but it was painfully obvious without going any further there is a clearance issue with the MR2 cooling system and the location of cooling pipes on the chargecooler itself.
If need be I can get the hard pipes/cut rewelded as required as i'd prefer a more
