[Mk2] [Turbo] Drivers side window won't go up properly
TheCombover
Post by TheCombover »
For some reason today my driver's side window decided to not go up properly, it goes up about half way and then the front jams while the back goes up fully. I had to manually pull the window up.
What could cause this?
abovetherim
Re: [Mk2] [Turbo] Drivers side window won't go up properly
Post by abovetherim »
i'm afraid you are going to have to get the door card off and have a looksee.
It could be a problem with the window in the runner or the runner has come adrift at the top or bottom. Have a look to see if any nuts or bolts are loose or knocking around in the bottom of the door.
Visibility of the runner is not good so you may need a small mirror to see whats going on.
Al-sw20
Post by Al-sw20 »
New regulator time.
TheCombover
Yeh sadly it was a new regulator time..
After destroying my hands I managed to fit it and it's all working again just needs adjusting :thumleft:
