[Mk2] [Turbo] Dual exit exhaust is wonky??
TheCombover
Post by TheCombover »
Recently fitted a greddy exhaust but the drivers side tip hangs lower than the passenger side.
What could be causing it???
gnzyza
Re: [Mk2] [Turbo] Dual exit exhaust is wonky??
Post by gnzyza »
damage/ bent hangers.
TheCombover
Okey cheers I will have a look tonight :thumleft:
What can I do if one of the hangers is bent? Tap the hanger with a rubber mallet and force it back into shape?
Post by Martin F »
TheCombover wrote:Okey cheers I will have a look tonight :thumleft:
Pretty much, just do it a bit at a time and check that it's starting to line up... you can always heat it also however it could be another issue. I had a similar issue once and I put washers under a mount to lower the exhaust to the correct position :thumleft:
TheCombover
Oh washers sounds like a good idea actually! I will give that a go this weekend :thumleft:
