Hi all, I'm having a problem with the dials in my car.
I filmed the problem today however didn't realise there was a post count before your allowed to upload videos.
Hopefully posting the link works/isn't against the rules, if so I will remove it as its only for reference.
tinypic.
(delete this space)com/r/2vwbiw9/9
The two issues I have are:
1.
Hot and cold spots and needles not lighting up
2.
Lights flickering when on full brightness
From doing a bit of research I'm guessing the problems with the needles and poor lighting are due to the fact I have blue bulbs.
Came with the car I wasn't sure what colour standard even was.
Took the bulbs out to have a look and they are like a tower shape, with one led on each side, rather then the type Shinny suggests using in his post
www.imoc.
(delete this space)co.uk/forums/viewtopic.php?t=166187&highlight=
Again I cant post photos yet so cant show the led side or the rear of them, they say Toshiba V-2 on the back.
Every bulb on the back of the cluster is one of these
(including the fuel warning light, which has turned on once while ive owned the car) so I don't know if I just need to replace the 4 like in Shinny's topic or if they are now all wrong? The only one that is different is a rectangle shape that says Denso on the back, I didn't pull this one out to have a look though.
Hopefully someone will say its a simple fix, follow Shinnys guide swap the 4 bulbs and ill have properly working dial lights and needles I can actually see.
(I presume Shinnys guide works exactly the same despite the fact I have a the battery dial instead of a turbo one).
The other issue is the fact they flicker, mainly on the rev counter between 2k and 5-6k but its sometimes just a little bit, other times its all over the place.
If I have the lights quite dim this doesn't seem to happen, or not that I can notice anyway and gets much worse the brighter you put the lights.
Is this also down to rubbish blue led lights or do I have an electrical problem?
Finally, once I get all of this sorted I have made a post in the wanted section for a clock
(time) on the dash as mine has burned out.
Again no idea what colour the clock is or even what it looks like on as mine has never worked but I see lots of people talking about changing the colour of them, is it easy to make it blue or white to match the dials
(but still be readable) and if so how.
Sorry for the long message, trying to get the car up together and finding this forum very useful so hoping you all can help clear up my issues.
Thanks, Geoff
