Halp! My radiator fan temp sensor appears to have gone to the great component store in the sky, and a quick phone call to Mr T. this morning had me hit with the 1-2 of "oh, that's £82.38" followed by "oh...and it's discontinued so we can't actually get one"
Any ideas where is best to get a new sensor from, I figure someone here has had to find the same part in the last year or so? Car is a Rev1 with aftermarket alu core radiator, fitted by Rogue when they did the engine conversion 3 years ago (I'd ask them, but they're shut until the 25th).
Radiator fan temperature sensor
Re: Radiator fan temperature sensor
Tcbparts or mr2ben
Post in the wanted section, I for one have binned several sensors over the years
You'll be able to get an oem sensor from the states still you'll just need to order it online
Cheers for the suggestions guys, will try the wanted section for now, am happy to wait a while as the fan will run constantly in the meantime anyway which isn't a problem. MR2Ben only have the oval plugged one in stock, TCB weren't showing any but will give them a ring.
