Sards are
£300 new, and as you say are a drop in fit, will support more power than you're looking for and have been used and proven in many big power builds.
The only other option is to go top feed, as I did
I used a sard fuel rail
(£150-ish at the time) Siemens deka 875cc injectors
(£200ish), height adapters from efihardware.com
(£35), a tomei FPR and gauge
(£100ish, I can't remember tbh but it was from RHDjapan) and then probably another
£150 worth of AN fittings and hose.
And a walbro 255lph fuel pump
£85ish.
That's pretty much the cheapest way of going top feed with quality parts.
You can get a whole top feed kit from ATS racing for about
$900 with ID1000 injectors but that's obviously plus tax and shipping and that doesn't include a new fuel pressure regulator.
If I were you I'd buy the sard injectors and save the rest of the money for something else.
