Sensor is industry standard Bosch.
Fully working, a few marks on the gauge front that would likely polish out but TBH only show up when the gauge is switched off as it's a smoked front.
Would be a great partner to someone running a Power FC
archangel wrote:Will it fit where the lambda sensor would normally go though? I have a motec M4 so it doesn't use lambda readings anyway so I have it sat plugged into the downpipe but not connected.
