I hope someone can help with this, Got a bit of repinning to do Just want to make sure I get it right first time around.
I've got a gen2 build, running on a gen3 loom, sensors, injectors and all the other things required to make this work.
It's had a couple of things deleted also, cold start injector, AFM, TVIS.
What I'm trying to do is connect an ECU that's PnP for a Gen2.
Now I can 100% confirm its all work fine on the gen3 ecu without issues, The bit i was looking for advice on:-
Is it a case of doing the Gen2 to Gen3 repin in reverse, but keep the AFM delete rewire in place?
This is the Layout im trying to pin to:-
