[Mk2] [Turbo] Front Turret ( suspension mounting point ) rubbers ?
JLW
Post by JLW »
Hi Guys,
Basically wanted to know if there is/was a OE rubber boot
that sits over the suspension in the Frunk, only reason I ask is that
part of my liners close to the arch had to be cut back with arch work
to fit my wide wheels.
Problem is that tends to throw up a lot of dirt and rain water into the
freshly detailed frunk due to running coilovers, and there being a gap.
Easy fix would be to just replace the rubber boot/gaiter/whatever you want to call it lol.
However if there isn't one as standard then that factors that out, unless I get one from another vehicle at the scrappies and neatly cable tie to fit ?
thanks,
Jordan.
