[Mk2] [Turbo] improving steering and front end feel
gnzyza
Post by gnzyza »
Hi guys, was looking at what people have done to improve high speed steering feel and front planted-ness :D
My cars lowered 40mm on yellow billies, fully poly bushed and full geo done. It feels great, very dampened and soaks up the bumps and corners flat etc
But at speed the car feels unstable , most noticed on smaller steering inputs.
I know the front end is light but wondered if there is anything worth checking, replacing steering, front side or any mods that would help.
The ps is working correctly.
androo007
Re: [Mk2] [Turbo] improving steering and front end feel
Post by androo007 »
Bag of cement in the frunk? ;)
Do you have the proper undertrays fitted?
A member here had the car corner weighted and swore by it.....
gnzyza
Post by gnzyza »
:D all under trays fitted. Would need coilovers to have that done.
The car handles fine in fact its great and goes exactly where you point it. I'm looking at getting that extra bite from the front and confidence at speed. [/list]
markstevieandmads
Post by markstevieandmads »
Is a jap import and does it have the delimiter fitted properly?
There is an issue that if there is a converter at the clocks end the power steering doesn't switch off at speed causing a light feeling.
You can overcome this by either fitting a stef delimiter or fitting UK clocks.
gnzyza
Post by gnzyza »
I had the clocks out the other day and nothing fitted. The ps is working correctly at speed. Its one of the things I've looked at as seen it mentioned here.
ashley
Post by ashley »
You know it makes sense...we've done two now, it's a pretty easy mod if you're prepared to get stuck in- and you can make it as straight forwards, or as complicated as you like...and I'd be happy to help once my car's running :thumleft:
thomp1983
Post by thomp1983 »
rev5 speed flaps if you don't already have them
gnzyza
Post by gnzyza »
ashley wrote:Image Replaced With URL For Quote http://i1276.photobucket.com/albums/y46 ... 9ee0ty.jpg
Image Replaced With URL For Quote [url]http://i354.photobucket.com/albums/r420/fomoashman333/Stramp1-6_zpsdbgtn9jr.jpg[/URL]
Thanks for the offer :thumleft: Happy to get stuck in. my plans were to keep the motor fairly standard looking but something to think over.
We'll have to meet up sometime and give your opinion/pointers on my setup.
thomp1983 wrote:rev5 speed flaps if you don't already have them
I don't have them, do they really make that much of a difference?
thomp1983
Post by thomp1983 »
yes surprisingly
Al-sw20
Post by Al-sw20 »
Yep my RX8 is fitted with speed flaps on all four wheels from factory. It is a ton more stable at speed than the MR2 was. Too bad it takes twice as long to get there :eye:
gnzyza
Post by gnzyza »
I'll try the speed flaps , where would one get them from?
Rob66
Post by Rob66 »
Beat me too it, well worth it. Mr2 Ben £55 or Mr T will get them for you.
ashley
Post by ashley »
Or just make some...
synXero
Post by synXero »
Doesn't work if you want to keep the stock looks but a proper front splitter would do a lot of good on an MR2.
Alternatively up the grip of your front tyres further? Go for a really serious tyre that you know has good grip. I wonder if you could get a PSS or something. Of course there's the AD08/R888 options but you really have to commit for that :lol:
gnzyza
Post by gnzyza »
If I was going to make changes would choose a aeroware or similar with a 40mil drop should make a decent improvement.
I'm planning on running a more sticky tyre(currently on T1R's) but want see what can else can be done.
I'm thinking mocking up some speed flaps from some Ali and use some bendy abs plastic to see if I can reduce the high pressure area around the wheel well.
The bulkhead seems the biggest problem though, venting that you can run a flatter floor past the wheels and control air flow better.
2barGee
Post by 2barGee »
gnzyza wrote:If I was going to make changes would choose a aeroware or similar with a 40mil drop should make a decent improvement.
Definitely change your tyres.
If your not tracking your car i'd recommend rainsport 3's they are really good!!
HighwayStar
Post by HighwayStar »
Nothing wrong with T1-Rs if you run the right pressures, certainly they've never made either of my 2s 'floaty' at speed. That said a bit of experimentation with those pressures may help… Are you running on standard wheels and rubber… i.e. 195/55/15 at the front?
Other considerations without changing from original specs (which I'd guess were designed and developed originally not to feel floaty) include I believe rubber components in the steering system which can perish just like the suspension bushes and of course those suspension bushes themselves…
What rev is the car?
R.
2barGee
Post by 2barGee »
HighwayStar wrote:Nothing wrong with T1-Rs if you run the right pressures, certainly they've never made either of my 2s 'floaty' at speed. That said a bit of experimentation with those pressures may help… Are you running on standard wheels and rubber… i.e. 195/55/15 at the front?
R.
They are by far the worst tyre I ever had. Useless in the damp or wet.
gnzyza
Post by gnzyza »
R.
My cars a rev3, anything in particular I can check or is serviceable? The car is fully poly bushed, handles great round corners just not planted at high speed, or confidence inspiring.
T1R's wont be causing the problem here, sure we can argue about grip level etc and I would agree they're not great in the wet. I will be changing to a more track focused compound.
2barGee
Post by 2barGee »
R.
What pressures are you running in the fronts? Might be worth dropping them a few psi. How old are the tyres you've got on now? What camber are you running at the front also?
