I read the Yellow/White go into the pressure sensor wire which I believe it blue and black in centre,small harness.
Red goes to power lead coming in on middle sized harness on right of ECU as you look at it.
And Black/Earth goes into a brown wire on the left big harness as you look at ECU.
