The ECU will be pumping out a tacho/speed signal on one of the pins which I am yet to wire into the dash but I was wondering is there anything else the power steering pump ECU needs to work properly again?
I had a look at the wiring diagram and found there were 3 pins from the engine ECU that went to the PS ECU
