Brake pipe and fitting diagram 1995 abs
samgpr50
Post by samgpr50 »
Hi everyone,
I am trying to find a diagram for the brake hard lines on my 1995 turbo. The part I am looking to try and find if the double 90 degrees elbow in the engine bay that joins the pipes. Mine is a little rusty and while I am replacing the pipes I though I would look and see how much a replacement would cost. Thanks in advance.
Sam
Nic
Re: Brake pipe and fitting diagram 1995 abs
Post by Nic »
This one?
Nic
[email protected]
MR2 Rev 3 GT Turbo
samgpr50
Post by samgpr50 »
Hi thanks but no it's a joiner that's in the bottom of the engine bay where the hard pipes that run the length of the car join to the ones that run out towards the wheels. The elbows are both on a bracket that bolts to the front firewall in the engine bay with two bolts.
Nic
Post by Nic »
Nic
[email protected]
MR2 Rev 3 GT Turbo
samgpr50
Post by samgpr50 »
Hi there is a joint similar on that diagram however I have two pipes that run the length of the car. Here is the part in question. Thanks again,
Nic
Post by Nic »
There are about 4-5 different versions of that joint depending on year, model and whether it has ABS or not.
I *think* this is the part you need, but I'm using an old copy of the EPC. You could try emailing Trevor at http://www.tcbparts.co.uk/ he'll probably be able to confirm the correct part number if you give him your VIN details.
Nic
[email protected]
MR2 Rev 3 GT Turbo
samgpr50
Post by samgpr50 »
Thank you!!! That really does look like the one. I searched for hours online before asking. Thanks again.
