Hi all im new to this forum i have mk2 turbo rev3 id purchased in December 2015 enjoying the car but have noticed suspension is a little tired up front and doesn't match the rear, black struts up front and yellow bilsteins out back, so i am seriously considering to install some bc coilovers br rh.
But i am indecisive on the spring rates.
I dont mind losing comfort and ride quality by going for the firmer option, my main reason for upgrade is for the handling.
I do understand a higer spring rate doesn't necessarily equal better handling for uk roads though.
And i am curious on anyones thoughts on softer springs and higher damping vs firmer spring rates and softer damping.
Any advise on this will be greatly appreciated thanks in advance, aaron
Spring rate options are front/rear
4/6kg/mm or 5/8 kg/mm
