Can anybody shed some light on wheel alignment settings? I've found some specs on the forum. My 2 is dramaticly low and I wasn't sure if this would change what my end result should be. The question I'm asking is with my car as low as it is also running wheel spacers my current alignment is going to be way off. Should I be trying to adjust everything into these specs.
[Mk2] [NA] Alignment help
Re: [Mk2] [NA] Alignment help
I have mine done to Dinos settings and it drives lovely but mine is only 30mm drop.
However with yours if you have lowered massively then you will need RCA spacers to get your arms back to near the right angle and you may need crash bolts to get the camber in spec. If you have adjustable top mounts (running coilovers with adjustable top mounts?) then you might get away without crash bolts
