[Mk2] [NA] Exhaust....
STUAW11
Post by STUAW11 »
I've got a totally standard n/a rev5...the exhaust is on the way out...joint between the back box and cat have rusted badly, I'd like to keep the car as original as possible but toyota exhausts are expensive...was looking at the magnex system...don't want noisy...just a nice note....not sure whether to put a decat pipe in too...how will this effect the running?
87 T-Bar Manual Supercharger
98 T-Bar Rev5 Sonic Shadow
SonicSW20
Re: [Mk2] [NA] Exhaust....
Post by SonicSW20 »
Bear in mind a decat won't pass an MOT.
Custom isn't a bad way to go, the routing on an MR2 is pretty simple, brackets are simple. If it's a good custom place they'll be able to make it to your spec with regards to noise.
As for off the shelf options on an NA, the best balance you're likely to find is a Blueflame or Mongoose. Neither are *loud*, but both sound much better than standard and are well made. Both can also be used with a stock cat so you won't have an issue at MOT time.
Rob66
Post by Rob66 »
I swopped mine for a mongoose, as Toyota wanted nearly a grand for theirs :shock: looks pretty stock and sounds great not too loud at all.
Tallboy
Premium Member
Post by Tallboy »
Magnex are a nicer looking exhaust and quieter than the mongoose in my experience.
