Car: Imran's AW11 SC
Problem:
Essentially, the signal from either the flash stalk or light switch to the Retractor Relay results in an earth on pin 8
This results in a positive output on pins 1 and 4 to the motors, which then work until the limit switch turns them off.
So far i have:
1) Changed RTR MTR and MTR fuses.
2) Confirmed i have full battery voltage at pins 3 and 10.
3) Confirmed i have good earth at pin 12.
4) Unplugged Retract Relay and a positive feed on pins 1 and 4 will work the motors
5) Tried 2 different motors.
6) Confirmed Retract Relay good by trying on another car.
7) Confirmed pin 8 is earthed when stalk pulled to flash.
8
9) In all cases, the headlight bulbs illuminate when they should.
Over to the IMOC massiff.
