Checked all the fuses in the internal fuse box.
One of them is No.6 20A fuse for door.
Also when sat in the car does the lock/unlock button work?
When you use the key in the drivers side does it unlock the passenger side?
It could be as simple as the motor on the drivers side is fubar or the lock mechanism is frozen.
One thing you can do is whip off the door card and put a voltmeter on the motor
+ve and earth and then use the blipper to see if it is getting 12v.
If it is then the motor is duff or the lock is too stiff for the motor to overcome.
